why would you remove the clips? are you going to use screws thru the mobo holes?
Go to the Arctic Cooling website and look up the page for the Freezer Pro 7. You will find instructions for removing the plastic clips.
In your bios make sure the fan control is set to PWM. My fan at idle only runs at 800-950 rpm.
Q-fan may be what they call it in the Asus bios. Try it and see
