Arctic Cooling Accelero GPU Coolers
Read the reviews for this cooler and it looks [H]ard.
But its not available at the at my usual haunt(Newegg, FrozenPC, etc)
Has anyone seen it for sale anywhere?
dosnt seem to preform any better than the previous lineup, but it dose however fit with SLI better...
still nothin to bust a nut about.
the new Accelero GPU Coolers from Artic coolin. (what this threas is about dua!)
They fit in SLI as there mmuch thiner than the NV series and cool the same.. (heat pipes used in them)
lol if it's quiet and can substancially cooler, I'm on it like a cheap suit.
I understand, unfortunately I need them now, or something that will work.
Google the cooler and you'll find a bunch of reviews that just came out. There's one on the [H]ome page here. I'm sure those will answer your questions about the SLI issue that all these coolers have. The reviews are all saying that they all are thinner and cause less problems with fit on SLI.
kwaichangkang, its is quite (as if the NV5 wasnt?) and it dose cool on par with he NV5 so why not? go for it. By no means am I saying not to.
theseeker, again im not sayign there is any reason to not buy it? its looks like a great cooler. I was just saying the only real advantage it has is the fact that it will fit with SLI setups... and the real disadvagtage is it dosnt duct hot air out the back like the NV5.
Just that there is not need to get excited over it like it drops 8c and alows better overclocking.. (it dosnt)
The drawback with that cooler is the fact it keeps the hot exaust from the card in your case, maybe not if you have a few 120mm fans to jet it out, but I still don't want all that hot air in my case.
I agree with that.
