Shaun_Dark_Lord
- Oct 1, 2008
Hi all
I installed an ARC-1212 RAID controller in my Main Gaming PC a few weeks back to try to avoid some major stbility issues I was having with my nVidia 780i motherboard. This worked for a while, but has still been causing issues with my SATA DVD drives. As a result, I've had to disable them.
I'm thinking of upgrading to the ARC-1222 and using the four extra channels to connect my DVD drives.
Is that ok? Will the DVD drives function OK? Will it impact on the performance of the RAID controller?
I'm also assuming that my existing ARC-1212 RAID array will be detected by the ARC-1222.
Thanks
Shaun
Thanks
Shaun
