Apr 3, 2006 #1 T the gamer [H]ard|Gawd Joined Mar 14, 2005 Messages 1,426 Hi when I run Aquamark 3 I always get this is there any kind of patch out that I need or is there something wrong with my driver's, computer etc etc ? Thanks.
Apr 3, 2006 #2 0 0V3RC10CK3D Gawd Joined Sep 14, 2005 Messages 751 Drop this file in your aquamark folder http://www.unrealfactory.net/direcpll.zip see if it works
Apr 3, 2006 #3 T the gamer [H]ard|Gawd Joined Mar 14, 2005 Messages 1,426 ok I am about to check to see if that file works but the error comes up straight after this pic but when I run the Demo it works fine its just the score measurement that does it.
Apr 3, 2006 #4 0 0V3RC10CK3D Gawd Joined Sep 14, 2005 Messages 751 Yes, i understand the situation, it's a common problem, just try the file =P
Apr 3, 2006 #7 T the gamer [H]ard|Gawd Joined Mar 14, 2005 Messages 1,426 May I ask what was the problem, was it something to do with the newer hardware or not?
Apr 3, 2006 #8 0 0V3RC10CK3D Gawd Joined Sep 14, 2005 Messages 751 yea, it's an issue with newer hardware, since the aquamark company is long gone they never had any updates to support new stuff, but that dll is also one that goes with 3DMark so you can just copy it over ^^
Apr 4, 2006 #9 T the gamer [H]ard|Gawd Joined Mar 14, 2005 Messages 1,426 I had a feeling they were gone, because the website is gone . Thanks for the tip also.
