Aquaextreme upside down/on side?
bmaffin13
just curious as to if i would have any problems mounting my Aquaextreme pump sideways or upside down? Any info would be great, thanks
I actually sent this question to swiftech and they told me the same thing. It will run in any position. The only thing they cautioned was if you are using a res, to make sure it is physically mounted above the pump intake.
Emailed them about the same thing and got the same response
so i second that
