BellaCroix
- Mar 25, 2004
Okay, so I finally got around to getting water in my new cooling loop... it's on it's 48 hour leak test right now but I've noticed something odd:
The loop is an Innovatek loop (CPU and GPU blocks, radiator, hoses, fittings, flow sensor, res) with the exception of the pump (an Aqua Computer modified Eheim) and the fan controller (an AquaComputer VFD Aquaero). The problem is that the flow sensor is reporting that I'm getting about 1.48 l/min.
I've changed the calibration setting to 232 impulses/liter as TN suggested.
Is that right? I was expecting to see something around .7 l/min from this pump and loop.
Any ideas what might be causing this to read this way? Am I missing something? Does that mean there's air trapped somewhere I can't find?
