Aquaero and third party pump
Autosaw
I am putting together a cooling system and I need to control the speed of a large pump along with the fans. I have an Aquaero controller, a dual 120mm fan/radiator, and a Coolpump 1511 (12V, 17 Watts). I need to keep the power consumption to a minimum, si I want to control pump speed to keep away from the non-stop 17 watt power consumption. The Aquastream seems to only be able to handle 5 watts/pump. I would like to find out if the Aquastream can actuall handle the coolpump or if I need to use a third party motor controller. I have had trouble finding a small motor controller that can run off of the Aquastream fan output as a control signal (0-12V). Does anyone know what the pinouts are for the aquastream bridge? Does it have a PWM or analog signal available?
