I installed a Aquacomputer D5 pump attached to a Aqualis 450mL with the fountain effect. That goes to my Aquacomputer flow sensor then to a 480MM Aquacomputer rad. I am just confused on how these pumps are stated to run at 300+GPH based on the setup and my sensor is only reading at 47.1 Gal/H at most. I don't have the Aquabus connected as of yet, only connected to the molex connector currently. I am still testing and figuring out everything. Is it because I do not have the 4 pin aquabus cable connected and not having the option of controlling the power?.
