Im looking to buy the Aquero 5 pro within the next week or so but need some help planning the setup.
A little background... I just finished rebuilding my PC with a corsair 900d. Has two 120x3 Rads, 8 core AMD and gtx 670FTW. yes, I know I have more rads then needed. (I want least ammount of noise as possible.) with all the fans in the case (14) i want to have good fan control... and I am not a fan of knob contollers that I have to tweek all the time.
SO...
I want to get the Aquero 5 pro.
I have seen there is a few flow meters, I was wondering what the main differences were between them, and what would be right for me. Im using the MCP655 pump. Also, how many fans can the unit support? with no extra accessories. I dont want to overload it. I have this fan splitter
http://www.performance-pcs.com/cata...e=product_info&cPath=34_451&products_id=38706
But it works with PWM... the aqero does not support PWM, correct? trying to figure out how I can support all the fans with this unit. Maybe I do need accessories?
If anyone could help me that would be great.
SO...
