Apt get in fedora?
Kinda...most sites that offer programs will offer a .rpm version which is made for redhat/fedora. Just download the .rpm and extract. You won't be using apt get, though...that's a debian-only thing.
<sidenote> ah Gentoo...with the beautiful "emerge [program]" command. God bless you portage... </sidenote>
Try "man yum" and see what that gets you.
Also, it is possible to install apt in fedora, but I suspect it's decidedly non-trivial.
Actually, installing apt in fedora is pretty simple - just google "apt fedora"
Ok, I'll take your word for it.
I still can't decide if using apt in Fedora is on the same level as using pkgsrc on SFU, though.
im sure there is an apt4rpm program and repository for fedora, I know there is one for SuSE.
This is the best place: http://atrpms.net then choose your version of Fedora and download the atrpmskickstart. execute the rpm and you have apt and synaptic ready to go.
ah okay...I wasn't aware of any apt get functions for fedora. It's been so long since I've used anything but Gentoo that I don't keep up with how the others have progressed.
I used APT-GET back when I had Fedora 1 & 2. Ever since I either used YUM or APT-GET in Debian.
http://www.fedorafaq.org/
very helpful site for fedora core 3
.. swap out custom yum.conf file and open up a terminal and type
yum install apt
(i think is all i did) ..and presto change-0 ..apt-get this or that works like a charm
not sure if stock yum.conf file will get you apt or not
..anyways , im just a linux noob of noobs and yum seems to make it pretty easy to install alot of different stuff.
