Approximately $1000 i5-750 pc
volt01
Gaming, and running engineering programs like AutoCAD
Preferably under $1000 I think I could get him to go higher
3) Where do you live?
Pittsburgh PA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything except Monitor, keyboard and mouse
Monitor
6) Will you be overclocking?
Yes
1920x1080
Soon
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI
support? etc.
He doesn't really need anything fancy with the motherboard just one that is overclock friendly
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yep windows 7 64bit. Go being a college student.
Here is what I have built, Plan on ordering this very soon maybe tonight. Just checking if anyone sees any problems and or better deals.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289 DVD $24
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283 750GB WD Caviar Black 65 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277 4GB DDR3 $100 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131620 ASUS Motherboard $130
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065 212 HSF $35
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.335362 125 Case and PSU
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.339394 i5-750 and 5850.
Mainly is the powercooler gpu any good?
Also how is the psu is it good enough?
After reading reviews I don't really like that mobo could someone recommend me a better mobo. We definitely want one that will OC well.
Antec makes good products that are reliable. also 650 watts is plenty. i have a 650 watt PSU on my 5870 with no issues. i haven't heard anything about power cooler but they only have a 2 year warranty unlike xfx's double lifetime warranty. why not spend just a tad bit more and get this graphics card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150455&cm_re=5850-_-14-150-455-_-Product
and if you live near microcenter get this processor
http://www.microcenter.com/single_product_results.phtml?product_id=0317379
only ends up being 20 dollars more and you get a better warenty on the card plus the factory over clocked card
there is a microcenter in philadelphia
Personaly, i like the way gigabytes boards are set up. for a better OC'ing board your gonna have to buy one that s about 160 but my Gigabyte UD2 over clocks fine and only cost 105
PSU is good. The GPU itself is exactly the same as the others, that being said, what really seperates brands is their customer support, and from what I have read XFX is the only really good ATI manufacturer when it comes to warranty and replacement (as well as double lifetime warranty). Powercolor support is meh, I havent' really heard too many horror stories or too many praises.
I just finished a $1k build for my buddy based off the i5-750 check my other thread in Gen Hardware for details, I'm really happy w/ the outcome (obv. would need a after market cooler if you're going to OC it- but you knew that anyway).
