Appropriate Vid Card for Appropriate Display
Alai
As I have been browsing around, people have been recommending certain graphics cards for certain monitors because there won't be any further benefit for having a better graphics card at a certain monitor size.
How do you know which monitor size fits best with which graphics card?
For example, how big of a monitor size can you go with HD 4850 CF? I have been planning on a 24" but could I do bigger without losing performance/reliability?
People are judging from own experience and reviews.
The native resolution for 24" widescreen is 1920x1200 and that resolution is putting quite a strain on your video card so you would need a rather fast one to get acceptable fps in games.
And keep in mind, not all games scale that good with crossfire/sli and sometimes you only get as good as what one card can provide.
That said, have a look at numbers in this review (crossfire test at the end of review). Crossfire 4850 seems to be good all the way up to 30" 2560x1600 resolution, but so is a single 4870 in most cases.
http://www.anandtech.com/video/showdoc.aspx?i=3341&p=12
A 30" monitor (2560x1600) is doable with 4850CF, although there's a chance that games coming out next year and later could require you to lower your settings. I would stick with a 24" monitor if you want to get the most longevity out of such a setup, although you could definitely go with a 30" monitor if you're comfortable with turning down a few settings when the time comes.
4870 would be better than 4850CF. Definitely go with a 4870 over 4850 CF. Single 4850 can do well at 1920x1200 but will get taxed more once you start applying the AA and move other quality settings up.
People are basing it in on the pixels that the video card has to render.
A 20"-22" widescreen monitor has a native resolution of 1680x1050 which means for every frame the card renders 1,764,000 pixels.
A 24"-26" widescreen is 1920x1200 which is 2,304,000 pixels. That's like a 30% increase in pixels.
If you go up to a 30" screen 2560x1600 that's 4,096,000 pixels. 77% more than a 24" screen!
4850 crossfire works great with a 24 inch i dont know why some people on here talk like theyre a bad idea.. the games i play they completely trample on a 4870.. just look at anandtech and guru3d's benchamarks... sure the 4870 can hold its on @ about 60fps in COD4 all maxed out but then look at the 4850 crossfire setup.. its over 100fps. of course it all depends on the games you play so go look at benchmarks and see what suits you the most.
http://www.guru3d.com/article/radeon-hd-4850-and--4870-crossfirex-performance/5
I think you could just wait for 4870x2 which will perform much better than 4850 CF and won't cost too much more because you won't need an expensive motherboard to take advantage of CF, unless you already have a CF capable motherboard.
4870x2 + 30" monitor = teh sex
I'm getting an 4870x2 and keeping a 4850 to power 2x 20 inch monitors. Just hoping I won't have to upgrade my PSU :X
