I just built a new PC with an i7 920. My HSF is the Xigmatek Dark Night.
I'm having trouble getting this cooler to effectively cool my CPU. The temps I'm seeing are basically dead-even with the temps I was getting with the original stock HSF from Intel. It seems that my thermal paste (AS5) isn't spreading adequately across the entire surface of the CPU.
I've tried two different application methods -- first a straight line across the length of the CPU, and then a dot in the middle of the CPU. With both applications, I twisted the Xigmatek back and forth a bit on the CPU before screwing it in place. However, upon removing the HSF after seeing higher-than-desired temps, I've found that the AS5 hasn't really spread much on the CPU. Probalby 50% of the surface has been clean with both applications.
So with all that said, does anyone out there have a better suggestion for how I should apply my thermal paste? I don't know if I should use some other technique that would work better with this specific HSF.
