Megalith
24-bit/48kHz
- Aug 20, 2006
Okay, this is really bothering me. I am in the process of building my second PC, and once again, I am having immense trouble with installing the CPU. In every guide I've read, you simply align the CPU, drop it in, close the door, and then pull down the latch.
The latter step is always a problem for me. I just tried pulling the latch down, but it just won't go down unless I put ridiculous---and I mean ridiculous---pressure on it, to the point where I think the latch will snap into pieces.
I eventually realized that I had to put some pressure down on the door myself and then align the latch so it would sit on top of the door hinge as much as possible so it could be pulled down. While I was able to secure the CPU properly (and hopefully the thing still works), is what I did really the proper way to do it?
I've talked with others who say pulling the latch part has practically no resistance whatsoever, so I'm confused.
For reference, I'm speaking of this part:
