crazymonkee84
- Jan 18, 2006
i got arctic silver 5 coolant paste to go with my 3200+venice in order to spread it completely over the processor should i use a toothpick?cutip?what do you guys use?
crazymonkee84 said:i just read on arctic silver how to apply it doesnt seem to hard but the 3200+ stock fan has a little thermal paste underneath the heatsink would i have to scrape that off or just put the coolant past eontot he processor leave that little pad and just put hte heatsink on with the pad onto the processor with the coolant paste??
Matt126 said:If you're using AS5 you must remove the thermal pad from the bottom of the cooler. Do not use AS5 in conjunction with the thermal pad. You can remove the thermal pad with any Xylene based solvent such as Goo-Off or any carbuerator cleaner. Clean it with alcohol after you've used the solvent to remove the pad.
Use at least 90% isopropyl alcohol to clean your heatsink.crazymonkee84 said:i got arctic silver 5 coolant paste to go with my 3200+venice in order to spread it completely over the processor should i use a toothpick?cutip?what do you guys use?
I use the dot method on naked chips and it works fine also. You just don't use as much.ChingChang said:Put a small dot in the middle and let the pressure of the heatsink spread it out.
If you were applying the thermal compound to a bare core processor, you spread out the thermal compound evenly with as little as you can. I use credit cards to spread mine.
http://www.arcticsilver.com/arctic_silver_instructions.htm
