Applying Appliques to Case, NOT Window
evilnickwong
A friend is bringing in some appliques from Shattered Web. I want to get some big thing to put on the side of my case that is just a bare piece of metal.
Can these window appliques be applied to case surfaces? I'm using an aluminium Tt Xaser II case, if the surface matters. :)
Im not sure what these are made of, but if its a vinal Sticker then Yes, Just remember to clean the surface really good and then Work the bubles out of the Sticker from the inside out.
Should work like a champ :)
Haha, yeah its vinyl. And after further checking, some reviews did use it on the case itself, so thanks anyway! :)
Just make sure the vinyl is the same color on both sides!
Some of the specialty colors I sell don't have the same color on the glue-side of the applique.
I did a review on them and applied a blue 10" or so one to a case panel. Just clean it off with alcohol first to ensure a good surface to bind too and apply it like a window. Make sure to tell them that's what you are doing, not sure... can't remember, but they have different kind of applique materials to make from. It turned out fine on my case...
Yep, works great, just go slow as you remove the backing (maybe a little slower than you would peeling away on plexi since the texture of the case will grab a little more), I put one on the inside of my front door, like so....
