Ashbringer
- Jan 25, 2010
Emulator is just an example. As we all know Apple limits what apps you can put on the app store. Not to forget the ability to customize the phone.I had an iPhone 3G and 4 and never even thought of jailbreaking it. And emulating a system with a controller on something that has a touchscreen? Meh no thanks.
They need to allow applications to be installed outside their app store, like Android does. Android pretty much does this without root, and rooting isn't needed unless you try to run certain apps or try to install custom roms.Granted I went to WP8 - the iPhone may have been a little easier to use, but any geek can adjust to software changes. Most normal people can't or don't want to change their phone habits and that's the only place Apple wins - their UI has barely changed over the years. It will work for awhile, but they're going to go the route of Blackberry if they don't start innovating.
