Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm looking for a simulator to be able to run Mac OS programs on XP, specifically Logic, as it doesn't come in a PC version. Anyone know of such a thing?
Well, technically it should be possible to build a virtual machine that emulates a Mac, but that would mean reverse-engineering a lot of proprietary Apple firmware and other things, plus breaking the law on a couple of thousand points.
There are also hacks and workarounds to install OSX on non-Apple hardware, again, illegal and tricky.
It goes without saying: EULA material is not law - and while OSx86 discussion is frowned upon here (www.insanelymac.com or www.infinitemac.com or other sites welcome it), people really need to stop saying "doing something against the EULA is breaking the law because it's simply not true.
At least not till the Supreme Court or something similar says it is.
