Well I've never been a real fanboy of either sides.
My very first smartphone was the original iPhone which was innovative at that time. Used it for two years before switching over to Android for then three years. Now I am back to the iPhone 5 which I fell right back in love with. It's simple, works, fast, and glitches less than Android did. I also hated how with each major update with the Android, they always changed some crap around that was very annoying (i.e. removing the contact list tab from the phone command).
Now with the PC world, I've always built my own desktops and owned a few laptops (Asus FX, HP, Dell). The HP and Dell laptops were only consumer series so the price were around $6-700. Quality was crap. Plastic body and hinges ended up getting loose after a year or two.
After I sold off my desktop, I decided I wanted a higher quality laptop..something thin and light. Now I've only messed with OSX a few times at the store and really had no clue how everything worked in it. So it came down to either the Macbook Air or the Samsung 9-series. I was also deciding between the 13" or 15". I took one look at the Samsung 9-series and noticed that the screen quality on the 13" vs 15" was completely different. Further research into it showed that Samsung used different panels on them..seems reasonable if only the difference in quality was not so apparent.
I ended up settling for 13" for better portability. At least the Samsung 9-series 13" had the good screen, and I was pretty set on purchasing the Samsung....until I found out that it only came in 4GB memory with no option to upgrade or custom order. Really?!
Now I'm a owner of a 13" Macbook Air which I use quite often everyday. I have gotten used to OSX and can see my future upgrades will be with Apple as well. The one thing I do love the best about the MacBooks is the mag-charge connection. IMO, all products should have this, but I guess Apple has a patent on it probably.
By the way, I don't see myself upgrading every year just because Apple comes out with something new. I only upgrade my phone every two years whenever my plan is up for renewal and I get the subsidized phone price. And since I don't play pc games anymore, the MBA will stay for quite a few years.
