Apple iPhone 4 Pre-Ordering Is a Total Disaster
HardOCP News
[H] News
Wow. What a nightmare this turned out to be. :eek:
Knowing the interest in every new Apple iPhone, and knowing that there are millions of people eligible for this—admittedly very attractive upgrade—how could this be? How could AT&T not expect this kind of massive load on their servers? Perhaps they used the same prediction software they use to plan their cellular network.
And it *still* managed to sell out all launch day inventory.
And again, Apple takes the heat for an AT&T screw up. Man, the Apple hate around here is blinding.
Apple's biggest failure is sticking with such a screwed up provider.
And again somebody fails to actually read the article.
Um, if you freaking read the OP, you'd see it's an ATT mess.
Nowhere is Apple blamed.
Strawman argument if I ever saw one :rolleyes:
Oh, and PS, Apple's servers collapsed, too.
I had a feeling something like this would happen. I didn't call my AT&T business rep about an upgrade yesterday. I'll wait a couple weeks for the storm to calm down first.
I'm sure Apple and AT&T both saw it coming. AT&T's ability to respond to infrastructure overload is quite poor, but poor or not, it was inevitable.
It happens to anything that's insanely popular. Blizzard's got the resources to keep their service running very well, but WoW's services crashed anyways during launch and again during expack launches. Some digital distribution sites crashed when Win7 launched too.
yeah, even radioshack is having problem, if all the ordering systems are down, does it mean that all of the stores are using one kind of system?, that is easily overloaded?
You apparently didn't read it all, either. For crying out loud people....
If you read it past the first few updates, Apple's servers have problems, too.
Enlighten me as to where it says this.
All the problems fall right into AT&T's lap.
If you are referring to Update 8 this was also an AT&T problem. Why? First off the screen shot DOES NOT tell the whole story. The reason the shipping was screwed up was because Apple could not get your current plan information (told by a chunk cut off of that picture).
Don't talk if you have no idea what was going on all day yesterday.
Update 8: The Apple pick-up reservation seems to be screwed for some readers too, like Mateen Alinaghi:
<<< Ummm... That screenshot has nothing to do with rate information. It's a scheduler that allows Apple to determine what Apple store you want to pick the phone up at.
Update 16: Some readers, like Ashley Conne, are reporting problems ordering the iPhone 4 with the new Apple Store App.
Really, this doesn't matter. It's more ATT's fault than anything. I'm just saying it's not like Apple is golden, here.
True, yes. But, Apple's servers depend upon AT&T servers. So, it is a inevitable chain reaction.
epic fail apple and atat, people want to bend over so you cam ram them in the ass but you can get it hard?
fail
(try viagra)
Apple chose AT&T as their only provider so yes it is also their fault. My gosh the itards just can't wait to spend money on an overpriced phone or anything icrap....
I agree with this 100%. Well, up to the point of the rant that is :)
I don't get it. Pre-ordering isn't new, what made this different?
Why do people insist on mentioning iPhone cost when it's little or no different from Android? :rolleyes:
Apparently ATT/Apple didn't expect so many people to want another minor upgrade :D
If this same exact situation happened on sprint or verizon, none of this "collapse networks" would happen. AT&T need to learn from these companies and build a better network that can handle this.
It's also perception of value... For example, overclocking an Evo can gain you 30% more power... So, to some, the value of the Evo is greater by not having Apple Nazi control over the device. Evo is also 4G, which I'd expect to be in most bigger cities next year from Sprint, whereas arguably Apple/ATT will be a couple more years on that.
But yes, Android is cheaper. Instead of spending money on both software and hardware, your money is primarily going toward that hardware, which usually means you end up with a beefier device.
$200 Evo - $300 iPhone (for the 32GB capability equal in the Evo)
$109/mo Evo for everything ($99/mo for plan, $9/mo for premium data 5GB) - $144/mo iPhone for everything ($69/mo talk, $20/mo messaging, $55/mo 5GB).
Over two years, the Evo costs you $1508.
Over two years, the iPhone costs you $2028.
Yes, the iPhone is more. Granted if you only use 2GB, the costs are equal (the iPhone is still a bit more), but in order to be "fair" one has to consider Sprint's 5GB data.
This would have been unbelievable some time ago but now it's so common that numb from it. No surprise, just straight on buttsecks.
Yeah...it's not just the iphone, I hate smart phones in general. All I want is a cell phone to make calls on. I don't need to play games or surf the web. I can do that on a laptop or workstation. The only possible exceptions may be getting work email or use get gps/directions functions... :p
\rant off
can anyone truly answer why AT&T is so shitty?
They clearly make a ton of money so what are they doing with it all ??? They can't have that big of an overhead???
this is giving me nightmares of what i went through last year for the 3GS. I'm glad i'm not going through that BS again this year. suckers.
i read somewhere that AT&T makes the most money out of the big 3 based on revenue. Even though verizon has a few million more customers.
I find it funny how people seek to find the "good guy" and the "bad guy" like the world is so black and white. This is life, not a 2 hour movie or after school special on TV. Both entities Apple and AT&T did not plan for the possibilities of this scenario. I see this from businesses ALL THE TIME. They (and us) typically gloss over possible problems then are shocked when they inevitably arise.
To overclock the EVO you have to have superuser permissions, which means you have to root the phone. People have to root Android just the same as they do iphone to do things like tethering. The only platform that seems completely open without any hacks required is the Palm Pre's webos. The 'Android is more open' is really just something people want to believe, but in reality as soon as you want to do something like tether you find isn't really true.
The EVO doesn't ship with 32GB memory so why are you comparing the 32GB capability of an EVO with the 32GB actually-in-the-box iphone? Technically to bring an EVO up to 32GB you'll need to buy an ~$200 32GB microSD card (and they aren't exactly easy to find either, the typical sites I buy flash memory from don't have them yet, found one on buy.com for $236), so a true price comparison is:
iphone 32GB - $300
EVO 32GB - $400
If you absolutely HAVE to have 32GB.
I think YOU'RE the one who didn't read the article...
Can you not read? TechLarry said article blames Apple when in fact it clearly states AT&T is at fault. I point out his inability to read the article and you quote the article where it says AT&T is to blame.
Jesus people...
Because only itards would stand in line for hours just to PREORDER or sit ont the internet clicking all day in hopes it may go through while not accidentally charging your credit card multiple times...I don't believe that happened with the Android? :rolleyes:
Oh, right. ONLY iPhone users do this. Nobody else. I got you. :rolleyes:
Or maybe you're just sore that iPhones are indeed popular and you just hate it when Apple gets ahead? I'm not a fan of their computers (OSX to be specific), but Apple doesn't make everything bad, you know? Or maybe you don't.
Not a fan of smart phones in general as stated in my previous post but Apple fans take it to the extremes for overly priced gadgets...Apple's issues all too often seem to be self inflicted due to their extreme proprietary nature and stubborness of Steve J...I also don't care if the product is good or bad it's just the stupidity of not being able to handle it when they KNOW it's coming!
