Apple Digging Into iPhone 3GS Battery Issues
HardOCP News
[H] News
Apple isn’t commenting on the reports of iPhone 3GS battery issues but it does appear that they are working on the issue. The problem that seems to be plaguing everyone is premature battery draining and poor battery life.
In some cases, users on the forums say the battery is draining while the iPhone is on standby. Other users say that after charging the battery overnight, it mysteriously drains after sending a couple of text messages or e-mails. Turning off features like Push Notifications and Bluetooth seem to have no effect for most users reporting problems.
Seems like it could be a charging issue. My own personal experience with the 3G is that it occasionally doesn't charge when plugged in to the AC adapter, even when it makes the docked chime, but it at least the battery indicator clearly indicates that it didn't do any charging. Maybe this is similar.
As for the battery draining during standby...well, it sort of goes without saying that the battery will drain unless it's completely powered down.
I've gotten the battery life I'd expect from mine for the most part. 3g data transfers seem to be incredibly power hungry for what they are doing and compared to other handsets.
The supposedly charged and drained after minimal use things sounds a lot like issues that plagued a DAP I had at one point. Bad solder joints connecting the battery would lead the device to think it was getting different voltages than it really was from the battery, and would halt charging prematurely and give incorrect readings on the battery meter.
makes me kind of glad I didn't upgrade. Although I must admit I played with one in the store and there is no question they are snappier.
i bought the phone under the guise that i could use it all day and not run it dead....if i run it all day there is no chance it will last all day...and ive only had it a month....i cant wait to see what happens after having the phone for a year or two
the battery life is horrible!!! If you listen to music or play games the battery wont even last 1 day without needing charged. Thats my only gripe about my new Iphone.
I charge my 3GS every night, but one day I noticed it was at 75% before I even got to school. It died by like 4:00 that afternoon, even though normally the battery doesn't go below 60% in a day. Happened twice to me, and I thought I had a dud, but then it happened to my dad, and now I read this post of others getting it. It hasn't happened to me since the 3.1 update, but it's still irritation that my phone battery may unexpectedly die at any point.
OS 3.0 destroyed battery life on my 3G. OS 3.1 has corrected some of it but not all.
There's a bug in the indicator too. It doesn't always tell the correct amount of charge left.
The only problem I have with my 3G 3.1 is that it randomly locks up forcing me to reboot my iPhone. I did not have this problem is previous versions.
Ok so what kind of battery life are folks getting.
If I do nothing but get my push email, calendar, imap email every 15 minutes, and wait for a phone call, I go to bed with anywhere form 75% to 85% battery left.
More commonly, i probably play about 1-2hr of games and maybe a few youtube clips over wi-fi, and make or receive maybe 5 minutes of phone calls. That usually has me at 25%to 35% battery by the end of the day.
IMO two of the secret battery hogs on the 3GS are the backlight and sound. It appears to be louder than the first generation or the 3g and a bit brighter by default. The auto dimming of the screen also appears to completely suck, thus leaving it at whatever you have set as the max, regardless of ambient light most times. I set my backlight at about 60% and play games with the sound turned off for the most part.
Using the thing as a GPS kicks it's ass though.
My HTC Touch Pro keeps a charge for almost 2 days.. oops... this is about the iphone.. sorry wrong thread :D
Music and local video playback takes up no power, I've used it for 10 hours on international flights and it barely made a dent on the battery life bar. About the only thing that really kills battery life (and its a big one) is heavy 3G internet usage. Do a lot of web browsing, internet radio streaming, Youtube, etc, and it'll hit the battery hard.
There has to be a bug with the battery indicator. I went out last night about 8pm and my phone showed 20% low battery. I was using it the entire night until 4am and it was fine after numerous phone calls, texts, and youtube.
Man, you sure can tell Apple spends a fuckload of money on QA. (Roommate is having the same problem. He found disabling 3G to help a little.)
I am happy with 3.0 on my iphone 3gs. No plan to upgrade till it is major and jailbreakable
3.0 gave me a slight battery life boost, if anything.
Yeah, the way the battery is queried is apparently pretty, well, whack.
Your little HTC Touch doesn't have any pull-my-finger apps now, does it? Get out of here with that inferior trash! ;)
Encode your videos intelligently and you'll find that the battery penalty isn't too severe. I try to target around 450kbps for video and audio with x264/AAC. Very nice quality overall, even at those seemingly low bit rates (though there are occasional artifacts). Obviously dimming the brightness as low as possible is going to be of huge benefit there too.
