Apple Cinema Display with 6800GT - EDID problem
nickwild
Upgrade gone terribly wrong
Got a Evga 6800GT and a new Apple Cinema 23 display on my XP box.
The card will not display bios screens, or even boot windows (yes I've waited for it to get to the desktop load with no luck). The only way I can get it to boot is to keep an analog vga monitor plugged in. When I do this the Apple comes up perfectly on the DVI port once in windows. The hugely ironic thing is that it works perfectly with my old 4200ti- BIOS screens windows boot screen everything works perfectly.
EVGA claims it stems from the monitor sending a non compliant EDID signal and have no bios fix to help. Apple could care less. EVGA said they have had reports of the ULTRA card working fine with the monitor- sounds fishy.
Anyone stuck in the same boat? If you feel like bagging on apple product go right ahead but I'd much rather get some actual help. From what EVGA has reported this is a problem with other monitors not just Apples.
Thanks
Since the DDC info comes in over a 2 wire channel in the video cable....maybe making a cable dongle that simply had no connection for DDC, then rely on manual setup of the monitor parameters would get the job done... temporarily? The display would act like an old monitor from pre-DDC days.
I have the hp 23 incher, supposedly the same panels. I do get problems like yours, but only in a certain point of windows installation, before the gui part and after the part where you install your sata drivers.
From what i have noticed, the horizontal refresh rates changes from a manageable 73.85 horizontal to an unmanageable 75.00 during that part of the setup. See if you can find out what horizontal refresh your screen is running at while its blank.
Thank you very much for the feedback so far. I've been able to retrieve the EDID information from the apple display but I'm not sure if I'll be able to possibly update it yet. Here is the EDID information. Does anyone know what the 6800GT might be looking for that would be confusing it? Please note this was pulled while running under my old 4200ti:
I'm guessing it is the supported resolutions? The monitor actually displays 640x480,800x600,1024x768 all just fine. Text mode for bootup stretches OK with the 4200.
Monitor
Windows description......... Plug and Play Monitor
Manufacturer description.... Cinema HD Display
Manufacturer................ Apple
Plug and Play ID............ APP921F
Serial number............... [REMOVED]
Manufacture date............ 2004, ISO week 31
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. 490 x 310 mm (~24")
Power management............ Active off/sleep
Color characteristics
Display gamma............... 2.20
Red chromaticity............ Rx 0.640 - Ry 0.332
Green chromaticity.......... Gx 0.288 - Gy 0.601
Blue chromaticity........... Bx 0.146 - By 0.065
White point (default)....... Wx 0.313 - Wy 0.329
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range.......
Vertical scan range.........
Video bandwidth.............
Timing recommendation....... 1920x1200 at 60Hz
Modeline................ "1920x1200" 153.970 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync
Standard timings supported
1920 x 1200 at 60Hz - Apple
1920 x 1920 at 60Hz - VESA
Raw EDID (1)
00: 00 FF FF FF FF FF FF 00 06 10 1F 92 A3 04 FE 02
10: 1F 0E 01 03 80 31 1F 78 2E CF B5 A3 55 49 99 25
20: 10 50 54 00 00 00 D1 00 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 25 3C 80 A0 70 B0 23 40 30 20
40: 36 00 EF 36 11 00 00 1A 00 00 00 FC 00 43 69 6E
50: 65 6D 61 20 48 44 20 44 69 73 00 00 00 FC 00 70
60: 6C 61 79 0A 00 00 00 00 00 00 00 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 0F
Display adapter
Adapter description......... NVIDIA GeForce4 Ti 4200 (Microsoft Corporation)
Adapter device ID........... 0x025310DE
Display settings............ 1920x1200, 32bpp
User/computer information
Registered user name........ [removed]
Registered organization..... [removed]
Network user name........... Administrator
Network computer name.......
Windows version ............ Windows XP
Windows build .............. 5.01.2600 Service Pack 2
Installation date .......... 4/11/2104 12:52:51 PM
One key help here.... in the slipstreaming process for winXP, you can use MSoft's Deploy-Tools setup manager to make a custom WINNT.SIF file, and in it you can specify resolutions and refresh rates. I dont think widescreen stuff is there, but 1280x1024 @ 60hz is certainly FORCEABLE. Should clear up some of the Windows booting up/wetup issues.
I have a similar proglem, eVga 6800U, and a Samsung SyncMaster 213T. I cannot get this monitor to show the POST screens. Sometimes, if my computer restarts quick enough, I'll see them. Usually though, the monitor just goes into standby until the WinXP loading screen comes up (with the blue bar). Im going to look at the EDID thing, that sounds like it could be it.
I sold my eVGA GT and got a BFG 6800Ultra OC. The BFG card works perfectly. Given eVGAs - you're screwed and we won't even pass this on to Nvidia attitude I'll be sure never to buy something from them again.
LOL, I plan on getting an Apple moniter so I'll have to remember this.
