Ok question:
I have a airport extreme, or some kind of airport. Looks to have to wired connections on it. One WAN and one LAN.
Now i have 3 computers with an ethernet cables running to a switch. If i run a cable from the modem into the airport's WAN, and then another cable from the airport's LAN to the switch? Will all the computers have internet?
Basically, does the LAN port on an airport output a routed/NAT signal? Or am I only limited to one connection through the LAN port on an airport???
