novadude said:Now if only they shipped to the U.S.
Edit: do you know anything about the store: www.bestplayer.de ?
What I do know about Bestplayer is that they only ship within Europe.
Martin64 said:sdclassic and novadude: I don't have any experience with those Keyboards, but that one looks awesome, it's all Aluminum. They do not come in black. The manufacturer is KeySonic (www.keysonic.de) and I've not looked elsewhere, but they can be purchased at www.caseking.de.
Happy Hopping said:do u own one? Is ea. key on the KB aluminum as well or is it just the frame of the KB that is Aluminum?
Martin64 said:First thoughts: No way I'm using my monitor arm with this, it's just too pretty!
Comparing the build quality between this and the HP L2335 is like comparing apples with oranges, and I don't like oranges that much. . Joking aside, I would have been happy with the HP if I had received a good monitor with no backlight problem.s But it's not a fair comparison considering it's more than twice as expensive.
Like I said, build quality is just awesome. It's one block of solid aluminum and so is the stand. The bezel is surprisingly thin for being such a big monitor. I've not discovered any dead or stuck pixels, and that's pretty amazing considering there are 2560x1600 = 4+ million of them, but I'll run Nokia Monitor test shortly to be certain. l
lb19984 said:Whoever wanted to cool their pc with the reserator
It wont be enough your gonna need two
Blethrow said:I've been watching that thread closely. I'll believe it when he shows me a pic of his case open with the card visible and identifiable, and an uninterupted DVI cable running to the monitor, which is unambiguously showing full resolution. Supposedly he will take and post pics next wednesday.
Not that I have any reason to doubt him in particular, but extraordinary claims require extraordinary proof. If it is true and confirmable, it's SLI time.
I'm not surprised. When I was considering the IBM T221 recently, I did some research for video card requirements and came across some users' experiences. The IBM display has similar requirements as the Apple 30" (both have native resolutions above 1920x1200) and there were claims that it also will work as yours did with either port. However, I distinctly remember that it was highly undesirable due to the substantially reduced refresh rate (<20Hz). So, YMWV.Blethrow: said:I will be really, extraordinarily pissed at Apple if they lied to me and effectively coerced me into buying a $1300 card when something much less expensive would do.
Interestingly, my display works at dual res on either port of my Quadro FX 3400. Only one is supposed to be dual-link.
Blethrow said:My understanding is that the Zalman case doesn't actually cool that well as compared to conventional methods but perhaps this matters less with the A64. If you can stand just a slight bit of noise I'd go with water cooling for much less money. I put in a Koolance Exos Al, and it is barely audible. It was noisy as hell at first because it kept sucking air into the pumps, but a little work with a syringe and a curved needle got most of the excess air out of the reservoir and that sorted it. Other systems would probably not require that extra work (but it matches the Lian Li so well...). You could consider the Zalman Reserator, but my understanding is that it doesn't cool all that well either, also because it relies on heat dissipation by convection.
Blethrow said:Happy,
Are you looking for pictures of the watercooling setup? I'm not clear on what you need.
I think that Zalman would work just fine. Looks like it might block the neighboring 2 slots though.
Would you like to adopt a 23 year old male who doesn't eat much and cleans up after himself?I just got a 30" ACD for Xmas and now I need to decide on which video card to pair it with.
