Apple 23" Cinema HD Display
JediKnight
Does anyone have experience with this monitor?
What type of panel does it use?
What are the specs on response time and for those who have used it how bad does it ghost.
I have one of the original 2nd generation (so the first revision of the flat silver panel, not the big studio display) 20" displays and it's incredible. I dont notice any ghosting at all.
I do know that Apple has improved their displays since this one... soooo
Does it support the full range of traditional PC 4:3 ratios as well as 16:10 ratios? From the info it shows on the product page at apple it has:
* 1920 by 1200 pixels (optimum resolution)
* 1280 by 800 pixels
* 1024 by 640 pixels
Is the monitor really not capable of displaying any other resolution? Also does it have a built in image scaler for 1:1 and 4:3 (ala black bars) like the 2407fpw? Well that is if it does do other resolutions than those three :p
Actually the image persistance issue I'm reading about with this monitor is making me lean away from it.
Should be the same S-IPS panel that all the other 23" displays on the market use (sony, hp, etc.). There is virtually nothing in the way of controls for the monitor though. Aspect ratios can be controled by the video card by having it do the scaling.
