Apologies, PCI-E speeds...956 chipset
TheRapture
Well.....whoodathunkit. My overclock was 99% stable....games were fine, but TAT would fail after a few hours...and leaving a Dreamscene going on my rig overnight or letting 3DMark06 loop overnight would crash the machine. Well....I had read from some guys about 1) raising the FSB past 400 a bit to get the next bootstrap, and 2) increasing the pci-e speed to over 100.
I ran my FSB up to 402, and my pci-e speed to 105.....and this thing is a brick, as in stable.
I ran 2 days and nights of Dreamscenes, with 2 instances of F@H going, and looped 3dm06 for 15+ hours, and have not rebooted or crashed. I ran TAT for 6+ hours with F@H going and same result, stable.
Despite my concerns about raising pci-e speeds.....I can eat some crow and try things others are doing. THANKS. What can I say, this bitch is kicking ass and I may try for a few more mhz.
I think you could have done this a couple of weeks back lol....... Ive never set mine below 110mhz and no probs at that speed.....
Corrupt, at the next bootstrap you lose performance..... but its easier on your NB....
Did you gain any extra performance in benchies after getting to the next bootstrap?
I have not tested real games yet...but a quick 3dm06 run was ~100 points faster....still pretty much within normal error margins....a fresh reboot can get 50 points easy, so really, I doubt I gained much in actual speed, just alot of STABILITY. The boost most likely was more from a fresh reboot and the additional 16mhz of cpu clock.
for the record, this is my 3dm06 run with Vista Ultimate, 3216mhz, and the 8800GTS at 600/925....XP would be faster yet...and I don't tweak for 3dm06, I install the drivers for my card, I run the bench at default settings, no control panel hacks, no fsb changing, etc.
What is meant by the "next bootstrap", and is this applicable to AMD CPUs/mobos?
My comp is about 4.5 hours Orthos stable, after which it gives an error. I want to make it more stable... anything along these lines work for AMDs?
Somebody watched too much Pirates of the Carribean :D It just "strap", not a "bootstrap" Bill :D
Strap, IIRC, is a setting on memory controller on intel platform, so it does not apply to AMD thanks to memory controller built-in on the cpu :D
