Does anyone know whether or not the included PSU with the X-QPACK2 is reliable? I plan on building a SFF system with that case, I'm just not sure whether or not to upgrade the power supply. The included supply has 1 pci-e plug and is 500W and seems sufficient, but then again it is an included PSU. If it helps any, here's the components I plan to use.
C2D E6320
ASUS P5B-VM
EVGA 8600GTS
2 HDDs
If the included PSU is indeed unworthy, any suggestions of a high quality PSU that will fit would be greatly appreciated. Thanks.
C2D E6320
ASUS P5B-VM
EVGA 8600GTS
2 HDDs
