APC PDU AP7920 Web-Interface
Der_OPT
Hello everyone,
I have the following problem:
The AP7920 reliably receives its network settings via DHCP. Login via telnet or FTP works.
However, logging in via the web interface is not possible: "There was a problem loading the application. Please login to the device via telnet for more details."
In the network settings, it looks like this:
------- Web/SSL/TLS --------
1- Access: Enabled
2- SSL/TLS: Disabled
3- HTTP Port: 80
4- HTTPS Port: 443
5- Advanced SSL/TLS Configuration
6- Accept Changes
All outlets are disabled. If you log in via telnet as Device Manager, there is no way to configure anything.
Is there a way to make the device usable again via telnet or even better via web? Do I need the serial cable?
The device is working perfectly again. I unplugged the device for about 10 minutes. After that, everything worked as it should. Apparently, the full reset only took place after that.
Thank you for your support.
