APC battery swap
ashman
Does anyone know if the older APC Smart UPS 1500's, the black ones with nothing fancy on the front but the two round buttons and row of vertical lights on either side, can you swap the batteries while the unit is live and plugged into power? Or do you have to shut them down and unplug them?
You need to shut down to change the batteries unless you have how swappable batteries (often in a module). What model number is it?
