Apache 2 - Trying to configure subdomains.
aeioa
Hello all,
I am having some trouble configuring my subdomains properly on Gentoo Linux with Apache 2.0.50.
Right now my current set up is as follows:
- Router (192.168.1.1)
- Main Computer (XP - 192.168.1.100)
- 'Server' (Gentoo - 192.168.1.102)
I have a NoIP address, for argument's sake, we can say it is:
example.no-ip.com.
I want to set the subdomains up so that:
example.no-ip.com points to /var/www/htdocs
-and-
test.example.no-ip.com points to /home/username/public_html/test
This is what my current setup looks like, I have no idea if this is correct or not.
NameVirtualHost 192.168.1.1:8080
<VirtualHost 192.168.1.1:8080>
ServerName example.no-ip.com:8080
DocumentRoot "/var/www/htdocs"
ServerAlias example
</VirtualHost>
ServerName test.example.no-ip.com:8080
DocumentRoot "/home/username/public_html/test"
ServerAlias test
</VirtualHost>
I've been trying to do this for hours to no avail, and it's really bothering me that I can't figure it out. Any help from any webmasters would be great.
Setting the port line to "port 8080" should do it. You can't specify ports per vhost (I could be wrong as I haven't actually tried it, but with the way vhosts work I don't see how you could)..
Try something like this....
<VirtualHost 192.168.1.1>
ServerAlias www.test.example.no-ip.com test.example.no-ip.com
ServerAdmin webmaster@test.example.no-ip.com
DocumentRoot /home/user/blahblha/public_html
*optional*BytesLog domlogs/test.example.no-ip.com-bytes_log
*optional*User tp
*optional*Group tp
*optional*CustomLog domlogs/test.example.no-ip.com combined
*optional*ScriptAlias /cgi-bin/ /home/tp/public_html/cgi-bin/
</VirtualHost>
Just tried your suggestion, and it didn't work :(
I forgot to mention in my earlier post that it does serve the documents, e.g.:
If I go to example.no-ip.com, I will see /var/www/htdocs
If I go to test.example.no-ip.com, I also see /var/www/htdocs
I don't get it. :(
ServerAlias example
</VirtualHost>
ServerAlias test
</VirtualHost>
Try taking out the port numbers all together and replace the 192.168.1.1 with a *...such as:
<VirtualHost *>
ServerAlias test
</VirtualHost>
I'm not 100 percent sure that will work, but its how one of the servers where I work is set up to an extent.
Let me know if that works...
Nope, this didn't work either, murph.
I really wish I knew why it doesn't work properly.:\
End of this thread.
The vhosts and subdomains worked fine...
after I realized I hadn't uncommented #Include /conf/vhosts/vhosts.conf.
>_<
Thanks for the help everyone.
aeioa said:
End of this thread.
>_<
D'oh !? Erm, yeah, that would do it.
Congrats
lmao :D Good to know it was an easy fix..
I have some rather complex vhost examples. Shoot me a pm if your interested ;)
