Aorus X870E Pro d9 code question
Niner
So I swapped out my MSI B650 board for the X870E Aorus Pro board recently. I did not reinstall windows and initially upon booting everything up got a TPM Boot error before it went into the bios, and I have not seen that same error since. Everything boots fine (quickly I might add), and have been using the system like this for a few weeks. Googling this hasn't been a big help. I have the latest bios and have checked to see if the ram is fully seated and all is good there. Also the ram is running in EXPO mode at the advertised timings. Should I just ignore this code since nothing seems to be wrong?
D9 seems like a pretty broad boot related issue. Do you have multiple drives?
Reactions: Niner
look in the bios boot options and take out anything that isnt your boot drive.
Well I booted up this morning and it's back. I'm just going to ignore it as everything is running fine with no issues. Boot menu looks good as well. I'm just going to attribute it to not doing a fresh install of Windows, and it is giving off some boot security issue.
just do it like a check engine light and put some black tape over it ;)
