AOC Q3279VWFD8 vs Samsung U32J590 vs Philips 328B6QJEB? Help me to choose ?
coolnext4
Hi everyone, i hope everyone healthy.
I want best picture quality between these 3 monitor. My usage is coding, movies, a little bit gaming. Picture quality and colors are most important thing.
Please dont recommend different monitor because alternatives not exist in my country.
AOC Q3279VWFD8:
2K
IPS Panel ( 8Bit + FRC )
%84 Adobe RGB, %98 sRGB
AMD FreeSync
75Hz
Samsung U32J590:
4K
MVA Panel (True 10Bit)
%88 Adobe RGB, %100 sRGB
AMD FreeSync
60Hz
Philips 328B6QJEB:
2K
%110 NTSC 1953, %128sRGB
60Hz
True 10Bit and 4K looks like great, i would like to hear your opinions.
VA screens (like the samsung in your list) tend to smear in dark scenes. Some are acceptable, others totally crap regarding this, from what I read even in the same model there might be considerable variation in this. However I consider 4k to be a must in that size. If you can buy it from somewhere with easy returns I would try the samsung out of the 3. With Philips I had multiple monitors with foreign objects (from what I could tell dust) under the screen (between the panel and the glass), might have been just me, but had it on 3 of their monitors, 2 different models, so again be sure to buy from somewhere with easy returns if you go for that...
