-=JacKaL=-
- Sep 23, 2005
like the title says the only complaint i have about this system is that it sits and the windows loading bar screen for a very long time anyway to fix?
Not really, your taking a very disk intensive process and pretty much giving a dedicated spindle during boot.P3N1X0R said:for what its worth.....i did this on my system
i have 2 raptors, 1 w/ os, apps etc, the other games, data storage etc...
used to take forever to boot XP....5 to 7+ passes of that lil bar thingy when its loading....
i moved my swap file to the 2nd raptor w/ games n data on it...
now it boots in less thasn 3 passes, ive seen it go half a pass and it switches to windows almost immediately....
but moving my swap file seemed to help the most...strange indeed isnt it?
-=JacKaL=- said:like the title says the only complaint i have about this system is that it sits and the windows loading bar screen for a very long time anyway to fix?
Exactly.MorfiusX said:Not really, your taking a very disk intensive process and pretty much giving a dedicated spindle during boot.
FiZ said:Google BootVis. Although it has been proven to have little effect as XP rearranges the boot files on your boot disk on its own after a period of time.
