Anyway to fix ULPS problem?
Drangueos
I have 2x 7950 in crossfire, the only problem I have with any driver (using 12.10 now) is if I leave the UPLS enable... when my second card jumps in sometimes my system crash and I need to shut down, unplug the crossfire bridge, turn on pc, log on windows, then shut down, plug the crossfire bridge back, turn the pc on and enable crossfire back on control centre.
If i leave UPLS disable I don't have any problems.
Is there anyway to fix this leaving the ULPS enable???
there is 1: hope for amd to fix their shit and come out with drivers that don't suck ass
For me the problem is usually the other way around with ULPS. When playing a game my second card usually gets bored while rendering and goes to sleep, crashing my entire system.
This has been a pain in xfire user's ass for ages
If I had a dollar for every time I have crawled the registry setting ULPS to 0
Of course every time you update drivers it borks your system all over again
