Anyway to control GPU fan speed?
Naldo
Our A/C is out an my room is hot as the devils crotch, is there anyway to make it so my GPU fan runs at 100% all the time?
The fan should speed up or slow down as needed. So, i don't think you'd have to make any adjustments.
Don't forget, computers and GPU are designed to run hotter then is comfortable for humans.
You may want to reduce you OC tho, that will really cut down on the heat from the GPU.
Naldo said:
So, is it posible to control the speed of the fan?
If it's a variable speed fan, it probably has a temperature sensor on it. You can't directly control the speed unless you modify or replace the fan.
the 6800's fan header's voltage CAN be adjusted. Download Expertool from gainward. Even if you don't have a gainward card, it will work. It allows you to overclock & adjust fan speeds. Works like a charm :D
