Anything I can do to increase OC?
r1fl3m4n
Info and stuff in sig
I just want to know if the voltage is safe and/or if I should up it to get the extra 100-200Mhz OC.
The CPU voltage is in the safe limit, the idle-load delta it's a little high, but the extra 100-200 MHz won't give you any spectacular gains... ;)
thats a major diff in idle and load - i wish i had that low of idle but nope... :p
really you won't see that huge of a gain - what kinda vid card are you using in that rig? - find out where your bottle neck is - more than likely you'd see more of an increase in a larger cache cpu than 1-200mhz all depending on apps of course
but you're already hitting 62c - getting closer and closer to about as high as you're gonna want to go - 70c is my safe limit in max 24 hour testing (and on a hot day)
Ahh okoks, I'm using a 3850, I guess I forgot that in my sig.
Anyways, I'll stop OC'in and live with my OC that I have right now. Everything runs absolutely great on this rig.
Thanks for the advice
