Anything better for the price?
Laforge
http://www.polkaudio.com/homeaudio/specs/individual/floorstanding/rti12/
These are the speakers I'm considering.
Best I can find is $699.
Code:
Driver Complement
Subwoofer 	3 - 7" Diameter (17.78cm)
Polymer Composite with Rubber surround
Midrange 	2 - 5-1/4" Diameter (13.34cm)
Polymer Composite Dynamic Balance with rubber surround
Tweeter 	1 - 1" Diameter (2.54cm)
Silk/Polymer composite dome
Electrical
Overall Frequency Response 	18Hz-27kHz
Lower -3dB Limit 	30Hz
Upper -3dB Limit 	26kHz
Nominal Impedance 	8 ohms
Recommended Amplifier Power 	50-500 w/channel
Efficiency 	90 dB
Crossover
(mid-high array) 	1.8kHz, 12dB/octave low and high pass. 120Hz 12dB/octave high pass
Crossover
(subwoofer) 	120Hz, 12dB/octave low pass
Inputs 	Dual (bi-amp) gold plated 5-way binding posts
Dimensions
Cabinet Size 	50-1/8" H x 7-3/4" W x 21" D
(127.32cm H x 19.68cm W x 53.34cm D)
Enclosure Type
(mid-high array) 	Sealed
Enclosure Type
(subwoofer) 	Ported via Power Port Plus
Shipping/Other
Total Shipping Weight 	88.00 lbs. (39.92kgs)
Speaker Warranty 	5 years parts and labor
Accessories (comes with) 	Outrigger levelling/carpet spikes
