Anyone with a P5Q and Linux?
Mcot
Hi, I am deciding on a mobo and the P5Q-E is the leading contender. The only thing I need to know about is linux compatibility specifically in the sata/e-sata/nic area. I don't expect there would be problems, but Ive heard of some motherboards not being supported so I thought I would ask real quick. For what it's worth I will probebly be running Fedora 9 or openSuse 11.
Thanks
I have a P5Q-E and I've run SUSE 10.3 and SUSE 11.0 without any problems. Ubuntu 8.04 was working until an update gave me a weird network problem. But I don't think that has anything to do with the hardware. Haven't tried anything with the e-sata though.
We all have Linux, its called ExpressGate on the P5Q. :p Actually I haven't been able to get Ubuntu to work, I'll try SUSE. Anyone been able to run a Linux Live CD? None of mine work???
Is the onboard raid on the motherboard windows driver specific??
I have an EP35 board with Ubuntu 8.04 and have also used Fedora 9 with zero problems.
Most newer gigabyte and asus boards use the same onboard Realtek or Marvell Ethernet chips which should be no problem for any linux that uses the 2.6 or newer kernel
