Anyone using these fan filters?
Well that's what it looks like you're supposed to do. Screw the grille/guard onto the fan then snap the filter onto it.
lol just noticed. Also just noticed that my fans are the type where you can only screw 1 side because the hole is blocked off... Thank you!
You know what I use?
Bounce dryer sheets. Makes the room smell like warm linen, and keeps the computer filtered. And they're cheap. And they're replacable. Did I mention it makes the room smell like warm linen? My girlfriend loves that sh~~. She calls me Snuggeluffugus.
