Anyone using the igpu as primary and Rift on other video card?
Discussion in 'VR & Head-Mounted Displays' started by davidm71, Nov 14, 2017.
  1. davidm71
    davidm71 [H]ard|Gawd
    1,260
    Feb 11, 2004
    Was wondering if anyone having issues running Rift from other video card aside from their primary video card? I’ve got my Rift on a gtx 1060 hdmi port and my primary display on the igpu. Problem is that I can’t see video movies on my Rift even though games play fine. I’ve found that I can fix this by unplugging the igpu cable or just extending the displays.
    Thanks
  2. aliaskary77
    aliaskary77 Limp Gawd
    221
    Dec 18, 2006
    is the 1060 display set as primary and the iGPU as extended?
  3. davidm71
    1,260
    Feb 11, 2004
    I set the iGpu as primary.
    The fact is it didn't matter I tried both ways and as long as the intel iGpu was active I got no video on the Rift.
    Want to make it clear that I could still play a 3D video game on the Rift but watching a movie would not work
    unless you either selected to extend the display or unplug the iGpu. Note the Rift could also work solely on
    the igpu but was doggy dog slow. Getting a ghost emulator today and should make for some interesting
    configuration testing.
    Thanks
  4. bobzdar
    bobzdar [H]ard|Gawd
    1,075
    Jun 6, 2003
    Did you try doing right click on the app you're watching the movie in and hit 'run on high performance nvidia adapter' when you launch it?
  5. davidm71
    1,260
    Feb 11, 2004
    No I didn’t try that as I didn’t know it was possible with the Virtual Desktop App I was using. Also does the same thing in PowerDVD VR mode. I’ll have to try it out. Thanks.
