Anyone using simple Sata 3 to PCIe adapters?
Dracarys
Hey guys,
I recently bought a low end LSI adapter for strictly reading to bypass the majority of sata 2 ports on my motherboard. The sequential reads/write are good (over 500mb), but the IOPs are cut in half sometimes when benched with Samsung Magician, which are most important in my line of production.
Specs:
3930k
x79 GA UD5
samsung pros and evos
My lsi card:
http://www.ebay.com/itm/New-IT-Mode...rt-PCI-E-6Gb-s-Controller-Card-/252344098349?
I have to set up a few more drives, I'm wondering if anyone has something straight forward like this:
https://www.newegg.ca/Product/Product.aspx?Item=9SIA66K3116880
Let me know your thoughts, if these don't bottleneck IOPs as much as the LSI, I might grab a couple.
The port multiplier will not be good for running more than 1 SSD. And if you are only running 1 SSD there is no point of it.
Remember it takes 1 input SATA port and splits the bandwidth of that 1 port to up to 5 SATA devices. I don't expect good bandwidth or IOPS with this. It is a hard drive geared device where people will be happy with 80 to 100 MB/s per port.
For the best IOPs connect your SSDs to the Intel ports. Yes even the SATA II Intel ports.
