anyone using Mushkin redline XP3200?
Bakku
is it good? and what's the minimum working voltage on this thing (@200 2-3-2-6)?
If thats where you wanna be, buy some cheap value ram. That stuff is for high volts and high fsb like2-2-2-5 @ 250fsb w/ 3.4+ volts. It would be a waste of money to keep it @ 200 fsb with 2-3-2-6.
LKS
i jsut picked some up. for 100 bucks! brand new a gig. im soo excited. im hoping i can pull some ddr520 2-2-2-5 action.
LKS
gotcha, i am planning to OC actually, but i have to mod the board first to get 3.3v. on mushkin's spec page, it says the ram module requires "active" cooling, does that mean i can just use a fan blow at it? or is there better active cooling choices?
you jsut need a fan blowing on it, that is their definition of active cooling. there are really no other forms of legit active cooling.
