Anyone using DFS?
marley1
So if I have a client that has 2 locations and we use DFS to sync up a Sales folder, for what I have been reading if a employee at location 1 opens file abc.doc it will open up on Server @ Location 1. If employee 2 at location 2 opens up the same file they will be opening it on Server @ Location 2.
Now are they both able to edit it? I would imagine so, but how does it sync back up>?
As I understand it, DFS will sync based on file modification times. ie: Last save wins.
I've only ever used DFS ( outside of netlogon, sysvol of course ) for readonly applications myself, so I don't run into this much. However, if you need both users collaborating on the file ( stop, collaborate and listen! ), sharepoint online is pretty cheap and useful in situations like these ( http://www.microsoft.com/en-us/office365/sharepoint-online.aspx ).
DFS will not combine files. Last save wins. Whoever changed the file last will prevail. Doesn't matter if they added 5 paragraphs or removed every line in the entire document except the title.
Whoever modified the document last.. only their changes will be in the document. That is why it is not a good idea for DFS to be used with 2 people accessing the same file.
We don't use DFS to replicate files, we just use it for namespaces.
so this current client has no server at the second location, they just access files over the VPN through a share.
any good way to speed it up? they are used to windows explorer and opening files through the shared drive. not sure if sharepoint will do anything.
they dont need to colaborate on files.
Easiest? More bandwidth at both sites.
Otherwise, you'd have to push the file local to the clients accessing it. Some NASes have a sync protocol, or you could do a windows server with DFS.
Sharepoint, however, is still not a bad idea. Especially if you pair it with the lite office tools; users can open the documents in their web browser.
Why are they editing it at the same time? DFS would be a great solution. We had this working for us and only ran into the last save wins on occasion
