Anyone using a Razer mouse on a Mac?
deFektive
My fiance recently bought me a Razer Deathadder, and while the mouse seems great, there are a number of issues with the difference in X and Y axis sensitivity, as well as diminished functionality of the two side buttons. Does anyone currently use a razer mouse on their mac? If so, do you use a program like USB Overdrive or Steermouse to compensate for the lack of drivers? .... or do you just game in Windows?
Apple actually sells a Razer mouse in their retail stores.. might be worth looking into that as it will probably not have software configuration issues..
Don't they have that Razer Pro 1.6 or something?
Its like white with blue lights.
I use a Razer ProSolutions 1.6 on my MBP. No major problems. (Only one is that in WoW I can't run by clicking the right and left mouse button, only by clicking the middle one.) Nice mouse. Install their drivers, they help a bunch. If they don't have any for that mouse and it has the "synapse" then you could try setting it up on a PC, saving the settings to the mouse memory, and hooking it up to the Mac.
