Anyone using a Q6600 with XP Pro ??
Zorachus
Just curious if anyone here has the QuadCore Q-6600 or any eXtreme quad cpu but using WinXP Pro and how does it work with that OS ??
Should run fine since XP counts actual sockets, you can have as many cores as you want.
So a QuadCore will actually get used in XP Pro if a App/Game is designed for multicores ??
Cool I just know the 2x2gb of DDR2 will get limited though to like 3.5gigs ??
Yes.
However, name five such games.
Give or take if you're pulling XP 32, but Vista 32 would do the same. For some reason they forgot to fix the extended addressing. :rolleyes:
Multicore(not just dualcore)games:
Supreme Commander
UT3
Crysis
World in Conflict
Bioshock
HL2: Orangebox
Lost Planet
Stalker
Oblivion
Others might know more...
I don't even borther with applications as the list is quite longer...
Supreme Commander
UT3
Crysis
World in Conflict
Bioshock
HL2: Orangebox
Lost Planet
Stalker
Oblivion
Actually WoW after 2.3patch is said to use multicores more than ever to run numerous game actions
