Anyone Used PhoneGap?
Justintoxicated
I'm trying to gather some information to create a native phone apps (first target would be andorid then Ipone, then BB probably) that can leverage existing Web Application servers (JBOSS).
I was thinking that the best way to go might be something like create an application using (GWT, JQuery, and HTML only) -> Can export to multiple phone platforms using phonegap libs,
This application would be able to access and serve data to the user by making servlet calls to the Existing Web Application (will need to add code to it of course).
I'm not the least bit familiar with JQUERY, or GWT though, so if this sounds wrong please chime in with any suggestions. Am I on the right track?
I have and honestly the end result was not nearly as good as writing a native iphone application. One framework that I've heard works well is Titanium. You still code in HTML, Javascript, and CSS but it will turn it all into native Objective C code. I have personally haven't used it, but with some of the iPhone apps on their demo page, I'm pretty impressed.
