Anyone use Sunbeam Theta Fan Controller?
Here is a Google search to help you form your own opinion:
http://www.google.com/search?hl=en&q=SunBeam+Theta+review
I have one of these and used it with the Yate Loon 120mm, Sunon 120mm, TT 120mm and Vantec Stealth 90mm fans. I did not hear any type of "whining" noise when dropping down to 7v. The software is simple yet it does perform quite well.
If you do decide to purchase one of these, make sure to mount the controller with your computer off, then plug in the USB cable and install the drivers once you have booted to Windows. Following their directions does not always ensure that the controller will be recognized by Windows upon boot.
From my perspective, even though the controller didn't come with standard 4 pin molex to 3 pin convertors, the price is well worth it for the performance.
Hope this helps you making a good, informed decision. :)
