Anyone running kernel 2.4.24?
rbrnk
Is anyone running kernel version 2.4.24 that is willing to send me the module shaper.o?
More than likely, the module would not work, as there are going to be different symbols exported between someone else's module and your own.
What seems to be the problem with your module?
I am running www.smoothwall.org as my gateway and I would like to implement an outbound bandwidth throttle. Smoothwall "ships" with kernel 2.4.22, which I can find a shaper.o module for and seems to work fine. Once I update smoothwall with the current patch it is at kernel 2.4.24 and the 2.4.22 module will no longer work.
I think as long as it is an i386 version of the kernel it will work.
