yeah have 2x 4870 crossfire or is it x fire anyways windows 7 bulid 7100 just fine.
only problem you have to work the vista drivers to get some hardware to work..
runs l4d great .ati has beta 9.4 7 driver also.
I'm using the 4870x2 with 7100 for nearly 2 days now and I haven't had many problems except that I don't think hydravision is available as a download? I'm not sure if it was actually called hydravision but a program by AMD for managing multiple monitors. In fact, if anyone has any advice about this I'd really appreciate it - I used to use it to switch out the outputs by hotkey when I move from my desk to my living room setup.
Found that in Windows 7 there is a nice inbuilt monitor management tool (right click on desktop).
Running a 4850 with Windows 7 Build 7100 with zero problems to date.
i tried and as soon as i install the cats 9.4 for my 4890 - black screen on boot, i can see my mouse but nothing else, and sometimes i cant even see my mouse
I had this same problem when I was fighting my code 43 on my 4870x2. If you can open up Catalyst, then the screen should brighten up to normal. I don't know why this happened and it only happened to me on Vista when I installed new drivers that didn't give me a code 43. After that, I could reboot all I want and not have the screen be really dim.
Getting major fps issues in TF2, especially when water gets shot it. Rig in sig with cat 9.4. Gonna reinstall drivers later and see if it helps.
Stock maps, or custom maps, alot of customs maps are just really badly optimized.
Anybody else getting a hitching effect when opening windows or folders. Talking about the Aero effect where instead of the window popping into existence it kind of expands onto the screen. Does it when closing too. Vista was totally smooth. WIndows would whoosh into existence and then whoosh as they dissappear when you minimized or clicked the X.
whoosh = silly I know, but I don't know any other way to describe it. Hope ya'll know what I'm trying to say.
Anybody else seeing this?
4890 with the WHQL Win 7 Cats from 5/5.
Well get this..lol stupid issue for me
I have the 2nd DVI port going out to my TV via a DVi to HDMI, for some reason Windows 7 likes to make my TV the primary monitor with the login and everything on it, no matter what port it is plugged into.. so when i had formatted, it was defaulting to my TV, downstairs, so my desktop LCD, i could see my mouse, but no login window, so i said, mmm let me type in my password and hit enter, sure enough i do and bam! i see my desktop on my LCD, unplug my TV and it works fine.
So FYI for anyone who may run the 2nd DVI port out to another device not in the same room, disconnect it first , even now, if i have my LCD set as the main device, and as soon as i plugged in my TV again, it moves the taskbar and everything over to the TV!!!, i then have to go into the display settings and change everything back, seems like a little bug in windows 7 display management.
