i was looking into asterik as a little project a few months back but it seemed extremely complicated to setup and im not very familiar with all the terminolgy, but today i just picked up the latest PC Magazine and was surprised to see it has a pretty good article on how to setup a asterik server using trixbox and simple softphone clients, it seems very easy there are alot of options you can configure that get tricky but setting it up and making extensions for simple phones on your internal network looks easy.
now setting up a trunk so you can place and get calls from the outside world im not sure how about, how exactly do you go about doing this? if you get a single telephone/pots line from your local phone company you just hook it up to a modem and configure the settings in trixbox?
now what if you want your internal users to be able to all make and get calls from the utside world at the same time can you use a single cheap line or would you need something like a t1?
like if you have 3 exenstions inside your network would only one of them be able to make or get a call from the outside world 1 at a time?
